Looking for an idea of price shipped for an enclosure that houses a pair of 12" Alpine type-r's (dvc 4ohm). Trunk space is 37Lx38Wx28H(height can vary but not to much more than 35"). Enclosure to be is a single box with dual chambers each chamber to be 1.7^3 ft. tuned to 33Hz. Kind of like "Model: 4.0@35Hz_12" pair on your site but different dimensions. Thanks for any help and great work all around from the enclosures to the site nice work.
3.4 cubes in seperate chambers will run $215 shipped for the standard enclosure. Extra options are available at an additional cost. Let me know if you have anymore questions.
appreciate it. how much for black carpet added. and will the enclosure look like the one i mentioned? thanks again for the quick response and help.
That price actually includes carpet already. It would be similar to that one, but the one you showed isnt seperate chambers. We would just need to basically add a center divider.
Thanks again for the help. Which version do you believe will allow the subwoofers perform better?
I think that depends a lot of install. I have heard people say each way yielded better results. For just daily driving, I doubt you will be able to notice a difference.
True true, when you say "3.4 cubes in seperate chambers" that's the 1.7 each side correct. sorry to be so detailing but i've not had a box built for my subwoofers before. thanks again for the patience.
Not a problem.
Yes 3.4 cubes is the total volume. So that would be 1.7 per driver.
