i have 2 jl w6s now and want to upgrade. are bl 12s better than w6 12s?
'Better' is a subjective term in this matter. What is your goals? What amplifier are you running?
What don't you like about the W6's that has you wanting to move on?
Just for reference's sake, the W6 is seen more as an SQ woofer where the BL is a ground pounder that sounds ok. Certainly not in the same class as far as quality of sound and power handling go.
I don't know what the hell is going on between you all but drop it.
I don't know how to get rid of a 'queued' topic but whoever did whatever fix it.
I don't care what you think you may know, I don't care if you think people ask stupid questions here. Get off your high horse and either encourage and help, or simply look the other way.
Your snide comments will not be tolerated.
Thank you.
I bet I know exactly what M5 was posting and I also bet it was exactly right.
Johnecon, if the OP would just have posted his goals, etc... in the first post there would be no need for you to explain all the differences between each driver, unless of course that was his question. You obviously can't answer his question with the information given.
To the OP...
We need much more information. Box size, ported sealed, intentions, goals, amplification, etc...
If I was to ask someone what was better, Milkyway candy bars or Carrots... Most would say, Milkway.
Then what if I was to tell you my intentions were to use one of these items as drum sticks...
