Posted November 21, 200816 yr Plan on running two sundown 1500's with two Odyssey 2150 batteries in the back and one Odyssey 1200 under the hood. Going to keep my factory 130 amp alt to run it. Question is, how many runs of 1/0 should I run from the front battery to the back two? Probably going to just ground to the chassis of the car in the back. Thanks for the help
November 21, 200816 yr Admin I agree, if you want to make the most out of the power those amplifiers can do, it does not hurt to have at least two runs of wire.
November 21, 200816 yr i have a similar setup 2 d3100s in rear, deka up front with 2 saz1500d's..i have 2 runs of (+)&(-) to the rear..helped alot..plan on adding another soon
November 22, 200816 yr Just remember, if your car has a frame, you are just throwing away money if you run negative cables front to back....
