Plan on running two sundown 1500's with two Odyssey 2150 batteries in the back and one Odyssey 1200 under the hood. Going to keep my factory 130 amp alt to run it. Question is, how many runs of 1/0 should I run from the front battery to the back two? Probably going to just ground to the chassis of the car in the back. Thanks for the help
  • Admin
I agree, if you want to make the most out of the power those amplifiers can do, it does not hurt to have at least two runs of wire. :)
i have a similar setup 2 d3100s in rear, deka up front with 2 saz1500d's..i have 2 runs of (+)&(-) to the rear..helped alot..plan on adding another soon
also agree here^^^^^^^
