Posted November 22, 200817 yr Trying to figure out how to get the 3rd magnet option on the BTL....I want to say I remember seeing it on their website as an option in the past --- has it become a standard? I only see the following options:Ohm configuration, p chamfer, cooling, hixm coil, daily or spl, induct heat ring, and the universal option.Thinking about getting a fully loaded BTL within the next month. Any help would be greatly appreciated.Thanks.Also, looking to get the AQ3500 amp w/yellow top up front, alt upgrade, along with big 3 upgrade.I listen to a lot of chopped and screwed music, so I think this setup would be perfect. C and S music isn't clean anyway - just good bass - so i'm not looking for great SQ.
November 22, 200817 yr Don't have the magnet options anymore, we went to a single 11.25" diameter slug.
November 22, 200817 yr Author Thanks for the quick responses. I fiured it was an older version - thanks.FYI: only doing 1 18" BTL Fully loaded in an expedition - lots of room for big box.What do you think about the amp?This seems like the most difficult part....Thinking about the SAZ-3000, TE4001D, MMats 3500.1, or the AQ3500D.....More or less, if i'm going to spend money, I want good quality. Now, pretty much I've heard pros and cons of most of them. I'm very interested in the sundown amp; however, if I'm going to spend that much, I'd probably be more willing to get an MTX TE4001D - and spend a little less. The MMATS and AQ are last on my list - but would appreciate some opinions on those amps as well. I think the AQ is fairly new, so I won't get too many reviews. Edited November 22, 200817 yr by alex_velociti
November 22, 200817 yr you can find saz's cheaper. but IT is worth every cent brand new. as sundowns service is #1 A+
November 22, 200817 yr Author Thats cool. I'm going to do some more research on those amps. I c u have one from your sig. Where the hell did u find an iraggi alternator?I can't seem to find a homepage or anything - been searching on google. The only thing I CAN find is on ebay. - but then again, I can't find an Iraggi HO alternator for my expedition.I did however find a 250amp HO alternator from Motorcityreman.com - it claims it does 120-140amps at idle. And 250 max.
November 22, 200817 yr Thats cool. I'm going to do some more research on those amps. I c u have one from your sig. Where the hell did u find an iraggi alternator?I can't seem to find a homepage or anything - been searching on google. The only thing I CAN find is on ebay. - but then again, I can't find an Iraggi HO alternator for my expedition.I did however find a 250amp HO alternator from Motorcityreman.com - it claims it does 120-140amps at idle. And 250 max.You have to email Iraggi, I believe they don't have a website. Try Mean Green, Powermaster, Excessive Amperage.I also vote yes to a SAZ-3000D
November 22, 200817 yr yes. and the iraggi alt is from ebay. for other good alternators try mechman too
November 22, 200817 yr ive also heard powerbastards were pretty good alts>> http://www.powerbastards.com/?gclid=CJeLrq...CFROgnAodNybSzw
January 12, 200917 yr Hifonics XXV Maxximus.Scroll all the way down towards the bottom of the page lolAMP
