ok the pups are here (see show off section)
ok I wanted to go with the smallest ported box design for them, if not small sealed, need help with the design...
I am not worried about space with my vehicles, but I might put the box into my girls civic, and not much space to work with,
hoping for suggestions from the designers :wub:
they will be powered by an RF 250a2 @4ohms mono for now (shown below) {334 watts benched, meaning 83.4 watts per sub, a little over the rms, but I can back the gains down}
  • Replies 52
  • Views 7.5k
D.- you looking for for get loud? nice daily? SPL?
For the Pups being so small & inefficient... I'm going with about 0.3ft^3 per 8".I have two, going ported in 0.75ft^3 with 8in^2 for port tuned to 58hz.
But i'm looking at cooking the little guys on the 2500D w/60hz tones... :D
I am looking to not blow them up and get the best sound out of them, so I would tune low as possible,
not expecting much just want to build something for fun
They can actually take a good beating
Aaron, i used a MA Audio M1889i ( listed in credits)
i'd say prolly around the .5-.75ft^3 nick suggested..
tuned 40-45hz
32in^2 of port total should be plenty in a shared chamber design..
that would be my recommendation..cuz
funky pups go boom like soooo
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
32 sq in of port for a 0.75 ft^3 box?? yeesh... that's a mile long port. LoL.
To put in a trunk car & sound decent, I would look for 0.75ft^3 with around 15in^3 of port tuned to mid 30's. It should keep your inbox impedance high enough to work with that amp as well. Assuming that you running them @ 1ohm nominal.
^_^
they would be at 4 ohms mono, and any help on a cut sheet my friends?
denim = :worthless:
I'd offer... but I have no good way of sending one. Sorry.
I can print something off of BBP6 tonight, if you like...?
Nick
Nick
:woot: x3
Nick
:woot:x3
mmkay. lemme know dimensions that you'd like. I'll input, print, scan, & mail.
:D
34" wide x 14" high x 14" deep
I was thinking just a basic 4 across with slot port along the bottom
would you like freq resp graphs as well? cause i dont remember where I put the specs for the Pups.. :faintthud:
with a 32x1 port?
Edited by NjccBflo
oh I fixed the mrspam img in the sig for ya
with a 32x1 port?
I will probably run 3/4" MDF, but yeah a short port
thanks... what was wonrg? i had the right code in... is it cause of being in a sig line?
I think in sigs you need to use tags instead of the board emoticons, there might be a setting some where I can adjust
meh.. so long as it works. thanks.
*What doyah like for tuning? And you want to go with the 32sq in of port as Kent suggested?*
I dont need to but if you two feel that is the best length to go with that cool, seems kinda long for this size box
and tuning I should go on the lower side to save some possible SQ
no, i too think it is WAY too much port for this enclosure. especially for these "woofers"...
I was thinking 12 sq. in's max. tuned around 32-36hz.
sounds like a plan to me :woot:
kewl. I'll get it together at somepoint tonight and shoot it to yah @ gmail.
Nick
Nick
:slayer::woot::wub:
YGM boss... + 3 Pup Pen attachements.
"I apologize for the crookedness, but the quality is high, so You should be able to zoom & crop as needed.
I hope this helps...
BTW, I loaded the spec that Ezekial posted... it don't look so good. But I do NOT believe that they are all correct.
Anyhow, good luck.
Nick"
sweet just checked email, maybe I can run up to Home Depot tomorrow
