February 9, 200521 yr hey dumbasses...lmaoi was suggesting .75ft^3 per sub..so 3ft^3total with 32in^2 of port..lol...for 4 subs!!!so it really wouldn't be that long, would it??make an ASSumption u become one...lmao...weiners..wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
February 9, 200521 yr what's funny is u and nick thought i meant a 32in^2 for .75ft^3..lol...u two misread my post...lolbut hey...lol...with 32in^2 of port in a .75ft^3 of box, u'll have zero port noise...hehewheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
February 9, 200521 yr sweet just checked email, maybe I can run up to Home Depot tomorrow<{POST_SNAPBACK}>important side note Aaron:BBP6 doesn't calc slot ports very well!!You'll notice that it has 4 boards for the port. Thats obviously wrong...You only need the top & two sides. I account the board thickness appropriatly in the program, s oyou dont need to worry about that. But only build the slot port with the top & two sides.If you want a full explanation, I'll type on in tomorrow during the day. Otherwise, I'm going back to the couch & watching this movie -and-Kent? Calm down yah wanker.-Nick
February 9, 200521 yr This must be the IHoP tonight huh?? The Pups have prevailed. Believe the hype! Any word on a PowerPup anyone(Nick)?
February 9, 200521 yr No new info about the power pupsPBUSA hasnt been on here, sent him a PM about the power pups
February 9, 200521 yr This must be the IHoP tonight huh?? The Pups have prevailed. Believe the hype! Any word on a PowerPup anyone(Nick)?<{POST_SNAPBACK}>Havent seen PBUsa around.... sucks too, he was gonna hook us up. Just pay shipping. I plan on starting up a convo with some other OEM's...Maybe Mike @ SS?Problem is... what can they do that'll work with a 1.5" coil?Unless someone's willing to graft a Pup cone & cap into another woofer's soft parts.
February 9, 200521 yr Author Admin thanks nick,I can't start building today, gotta run around (sorta still moving)
February 10, 200521 yr I wish to have no dealings with RE. I am thinking about adire though. The 15" pup should be here late this or early next week. I'll go from there.
February 10, 200521 yr You won't get anywhere with Adire right now. I can tell you that much.<{POST_SNAPBACK}>any particular reason? other then them reorganizing et al?
February 10, 200521 yr You won't get anywhere with Adire right now. I can tell you that much.any particular reason? other then them reorganizing et al?That's the exact reason. Well, to my knowledge at least. Now if you were to come in there and flash a TON of money, you will probably get something done, but a small piece or order, forget about it.
February 10, 200521 yr hey nick how did you blow the pup?:253: <{POST_SNAPBACK}>this was the damaged 8".I figured that I'd tear it apart to get a look at the coil.
February 10, 200521 yr Author Admin hey nick how did you blow the pup?:253: this was the damaged 8".I figured that I'd tear it apart to get a look at the coil.ahh ok, sorry I dont keep up with everything on SIN much anymore, I am only there for the group buys and Momentum
February 10, 200521 yr hey nick how did you blow the pup?:253: <{POST_SNAPBACK}>this was the damaged 8".I figured that I'd tear it apart to get a look at the coil.<{POST_SNAPBACK}>ahh ok, sorry I dont keep up with everything on SIN much anymore, I am only there for the group buys and Momentum <{POST_SNAPBACK}>LoL... i dont blame you. I pretty much treat it the same.
February 11, 200521 yr Author Admin its a cool site, some of my best online audio buddies call home there, but I am not always a fan of some of the other regular posters there, I just never felt all that comfortable there
February 13, 200521 yr Author Admin sweet just checked email, maybe I can run up to Home Depot tomorrowimportant side note Aaron:BBP6 doesn't calc slot ports very well!!You'll notice that it has 4 boards for the port. Thats obviously wrong...You only need the top & two sides. I account the board thickness appropriatly in the program, s oyou dont need to worry about that. But only build the slot port with the top & two sides.-Nickwhen you mean the top and two sides, do you mean the top and two sides of the "vent parts" or the top and two sides of the "box parts"meaning are you saying the bottom and sides of the port are the bottom and sides of the box,
February 14, 200521 yr i only mean that the bottom of the port is the bottom of the box. you only need to attach the port sides & top.
February 14, 200521 yr BassBox does not account for a slot port. Just a square port. I use it as a reference for port area, then simply enter 0 for the volume the port displaces, figure out my vent length for desired tuning, then add the interior port walls to the miscellaneous objects inside the enclosure to account for their displacement and BINGO!
