I Have A MLT setup and I want to know the advantages of this setup.I have two md3d going to two 13w7's. Under this setup I have one md3d going to my subs and the other is a slave amp.The advantage I have with this setup is I only have to play with one gain on the amp which is good and also when I had played with both amps before I have to make sure that both amps were even on the gain so the subs would move the same.Now with the new setup the subs are more even when they are under excursion so better sound.It seems that the subs hit harder and cleaner. :bigclap: :foshizzle:
  • 2 weeks later...
You stated your own anwser, MLT either allows you to strap 2 amps or run them in a master slave configuration for a single gain control.
