Hey bj i am looking at putting a fully loaded 10" FI BL in my standard cab silverado 2000 - 2006 bodystyle. The dimensions i would have would be around 40.0"W x 15.5"H x 7.5"D. It would also have to be a wedge type enclosure because it is going behind the seats.
Something like this but 1 10" sub and ported to around 32-34 hz is what i was thinking.
Also, what are the advantages/disadvantages to running aero ports vs slot ports. I was thinking of running 1 or 2 aero ports out the top of the box.
Please let me know if you have any suggestions about the port, tuning, or anything else.
Edit: Forgot to mention i am going to be running a SAE-1000D to it. What would you recommend on the Cubes of the box? I was thinking around 1 cube but not sure. I mainly just want loud, shaking, low bass.
Thanks,
Drake
Edited by juslivin
I will need to get you in contact with my designer to work on your application. But aeros are good to use when space is an issue. However, the extra bracing provided by a slot port is nice. But overall, in a daily driving application you are not going to notice a difference one way or the other.
I did notice that with the mounting depth of the driver, its going to probably be a tight fit. By the time we angle the front face of the enclosure its going to make things tight. Only way to find out for sure about fitment, is to get it modeled up.
To get a design done, please email Chris (at) fishercustoms (dot) com.
If you need anything else, just let me know.
There only is a 1999-02 and 03-06 body style for silverados....
sounds like a good daily pounder for a single cab
