Hi i just installed a hifonics bxi 2608 im running it at 2 ohm at 1700 watts. my box is tuned to 34 hz @3.5 cubes. my bl is over extending itslef so i turned down the gain. My question is what should i have the low pass filter set at right now i got it at around 75 i think thats too high. it kind of sounds messy. and if i turn it down could i put the gain a little higher?
Edited by The Storms
just play with it a little bit, try setting it to 35 at first, if you like the way it sounds keep it, if you dont keep going up
mines at 28Hz
