Posted December 14, 200817 yr Configure Speaker: Ohm: dual 1/dual 2 P Chamfer: no/yes +$10 Cooling: no/yes +$40 HiXmCoil: no/yes +$20 Daily or SPL: Daily/SPL Induct Heat Ring: no/yes +$25 Universal: no/yes i just wanted to know mainly what i should get and what it does for the speaker. i was purchasing two of these if you need to know.
December 14, 200817 yr I am assuming you are running 2 Sundown SAZ-3000D's in a daily driver. To get ~3000 watts to each you will want D2 coils so you can wire to a 1 ohm load, cooling, HiXmCoil, Daily, and Universal. It is recommended that you have 250 amps available for each one of those amplifiers. That is some serious juice.
December 14, 200817 yr Read this topic please http://www.soundsolutionsaudio.com/forum/i...?showtopic=7153It will answer all your questions about what the options do for you.
