Posted December 15, 200817 yr Is this battery still for sale? I dont see it on PMs website, nor do I see it on any of the online dealers websites. If it is still produced, does it come with the i-BAR system, or is that an extra add on part? If so how much does it cost? And will it fit any other PM battery?
January 10, 200917 yr I just got a 3400d so Im sure they are still being produced and as far as the other thing I think its extra because I didnt get one with mine
January 11, 200917 yr i got the i-bar kit with my d3400.it is great for my use.it has 1 side and 2 top mounts.came with two different type of posts and some hex bolts.it interlocks with the batt, and looks like it belongs there.i think it was only $25-30.i used the side connection to bolt my 1/0 jumper with ring terminals to my alt+i used one of the sets of posts for my stock batt wires terminals, on top i used the last top connection to bolt my ring terminal for my 1/0 run to the backthe same with the neg side groundstrap , stock and 1/0 run to back all get there own connection.verry clean and i did not have to alter my factory wires.i think that there is different configurations for i-bars with different part numbers.if you need i could go look at the packaging to get which part number this kit is.
February 5, 200917 yr Yes, the D3400's are available, and yes the I-Bar accessories are sold seperately and they will now work with all of the XS Power models excluding the 680's. For some models you will need adaptor parts, so please be sure to check before you buy.
