Need a solid amp, roughly 4-5000w, around $1000 to power 2 18" BTLs. Ideas? What electrical am I going to need? Can I get away with 1 HO alt and a few batteries?
id look into an atomic 5000.1 can be had around that price or you could get a pair of saz3000d and strap them get them from db-r.com cost about 1300. as far as electrical a good ho alt and solid battery bank should be fine just get good batterys 80+ah ratings d3100's or similar.
Lanzar Opti6000D can be found new for around $1000.
Almost same internals as the Soundstream XXX10000. some claim better results with the Opti6000D
POWERBASS 4000D
1-HO ALT.
AND 4 -2400 BATTS.
WILL DOIT!
CHECK FOURMS THERE ARE SOME 4000D'S OUT THERE RIGHT NOW FOR 6-8 HUNDRED A PIECE
RUN 2 OF THEM TO 4 FI BTL 15 AT 151.8 PLAYING MUSIC
