Posted December 18, 200816 yr Two 12" woofers taht would be able to handle my soundstream xxx 6500 amp.....
December 18, 200816 yr whats the rated RMS on that amp?welcome to SSA!6500 WATT RMS CONTINUOUS POWER OUTPUT @ 1 Ohm!Is what i saw when i did a google search for it
December 18, 200816 yr Also, an audiopulse LMS-ultra 15" will take 5000W or 2 12" axis will take 2500W each.
December 19, 200816 yr son... id run an orion HCCADo we have someone who was addicted on the HCCA because of their biased youtube videos?
December 19, 200816 yr Whats the rms ratings on that ddz12?That things really long, the sub itself kinda resembles a 10" bazooka tube with its length
December 19, 200816 yr Whats the rms ratings on that ddz12?That things really long, the sub itself kinda resembles a 10" bazooka tube with its lengthInfinity It has an insanely high power handling, but it is strictly a burp woofer.
December 19, 200816 yr 2 btls for daily music. the DD woud be nice for farts. is your electrical sorted?
December 19, 200816 yr Good gawddd...I wonder if you could burp it with 20k?You sure could. I believe Alan Dante uses 28K on his.
December 22, 200816 yr I'm kinda partial to the Sundown Audio subs since that's what I run in my vehicle. There is a teamate of mine that throws 5K per Nightshade 18 to his and they hold up for the most part. He's broken quite a few, but if he were to be more careful with them they would take the power a little bit better. If you were to put 3K to each of them even for daily I'm sure that they would hold up no problem. Contact [email protected] for info about the woofers.
