December 19, 200817 yr it modifies the signal. You can get an EQ, which allows you to adjust the levels of certain frequencies up and down. You can get a crossover, which sends only ideal frequencies to the individual speaker in the system.How much greatly depends on what you're looking for, what options, and what brand. It can be from 20 to 2000 or more, just like amps or subs.You would need one if you want to modify the signal.
December 19, 200817 yr It will also include time alignment, for compensating that you are bound to end up on unequal distances from your speakers, which you remedy with this feature. You will have more options to adjust the sound to your satisfaction and in a more convenient way, as many of the present processors can/must be set from a portable computer.
December 20, 200817 yr Author If my head unit has setable crossovers (Alpine CDE series) would I still want/need one?
December 20, 200817 yr It all depends on what you are looking to do, if you fill us in on the goals for your setup we could give you a better answer.
December 20, 200817 yr Author I don't have any goals and this is an entry-level system that I want to be better than entry level. I know enough about electronics to be dangerous and that's it. I have money to spend but don't want to get out of control ( this is not for competition ).I'm trying to tweak this plan ( but everyone tells me the stuff I'm thinking about buying is crap!) -vehicle : '01 Tahoehead: Alpine CDE 9874 45X4 already in ( has setable crossovers)door spkrs: Mid price range Alpine (forgot model) already in4-channel amp: Alpine RP F300 75X4 purchased but not inMono amp: Hifonics Brutus 2000WSubs: Power Acoustik MOFO-12 1200W enclosure: Sonic ported 3.0^3ft
