Posted December 20, 200817 yr 12" Kicker CVX12D2 750W factory renewed or Power Acoustik MOFO-12 1200W(probably overrated) new for same price.Obvously Kickers are better subs, can factory renwewed be trusted for quality and longevity. Don't knnow why they say renewed and not refurbished, that kinda scares me.
December 20, 200817 yr why do you automatically think kicker is better? i'd go with whatever you feel sounds the best. i haven't ever heard cvx's before, but a friend of mine had a 15mofo that got pretty loud, and took a TON of abuse (and power) for years before giving out. what kind of amp will you be using?
December 20, 200817 yr Factory renewed is as good as new. The CVX will take a lot of abuse. The MOFO, it is extremely peaky and overrated.I'm guessing the price is $350? If so why don't you go with some Fi, Ascendant, or even Sundown?
December 20, 200817 yr Factory renewed is as good as new.x2 they may have some cosmetic flaws on the magnet or basket but work just like new they are just Re-coned with new softparts as for the mofo's... I've heard a pair and they weren't terrible, got fairly loud and sounded ok (I can't say good but good enough for the average joe) depending on what you're paying you may have some other better options in the same price range
December 20, 200817 yr yeah, what kind of prices are you looking at? if theyre dirt cheap (like my friends 15mofo 139 shipped to HAWAII), then go for them. if not, i'd go with something along the lines of what was suggested.
December 20, 200817 yr Author The MOFO's are $139 Kicker renewed are $149.I get different answers every time I ask about MOFO's. This is my price range so it's one or the other. (MOFO's are 1ohm coils which makes them more appealing, Kickers are 2ohm)WHAT WOULD YOU DO?Going to power 2 w/Hifonics amp either Brutus 2000W or 2400W in ported Sonic box 3.0^3 ft.Just an average Joe showing off to other avg. Joe's (and their girlfriends-wives-sisters and uh! daughters) Edited December 20, 200817 yr by buttmonkey
December 20, 200817 yr if you want 2000 watts, you should get the brutus 2400w and upgrade your electrical.
December 20, 200817 yr Author Amp is 950W @ 2ohm or 1200 @ 1ohm 2 subs in parallel will only be getting about 600W max depending on how I wire them.
December 20, 200817 yr 2 ia lethal injection 15's 168 each dual 4 wired parallel to 1ohm. 600rms each 1200w for the pair.
December 20, 200817 yr Author That sounds like a feasible suggestion but I was told 12's would be better for me because I listen to more Rock/Pop rather than Rap so 15's have more distance to move to keep up with double bass hits.
December 20, 200817 yr http://www.audiopulse.com/know-how/subwoof...out-subwoofers/Myth #3,8,12 Edited December 20, 200817 yr by Bobaflob
December 21, 200817 yr That sounds like a feasible suggestion but I was told 12's would be better for me because I listen to more Rock/Pop rather than Rap so 15's have more distance to move to keep up with double bass hits.other than the fact the size of a sub has nothing to do with what it can play if you cant fit 15's the 12's are 152 each
December 21, 200817 yr 2 ia lethal injection 15's 168 each dual 4 wired parallel to 1ohm. 600rms each 1200w for the pair.http://www.audiopulse.com/know-how/subwoof...out-subwoofers/Myth #3,8,12double up
December 21, 200817 yr 2 ia lethal injection 15's 168 each dual 4 wired parallel to 1ohm. 600rms each 1200w for the pair.http://www.audiopulse.com/know-how/subwoof...out-subwoofers/Myth #3,8,12double upx3 :clap:
