Posted December 22, 200817 yr would you guys recommend-1. running power from battery to the cdplayer instead of using the factory harness?2. grounding to the fire wall or use the factory harness?deck is the clarion mentioned in my build log (the cheap one that can do active)
December 24, 200817 yr Author my hu has 2 power wires aswell. one a 3 amp fuse and the other a 15 amp. bumb for help!
December 24, 200817 yr One power wire is probably the constant 12V source and the other is a switched 12V source. I would use the harness and add a ground to the rear of the deck, there should be a screw to attach one.
December 24, 200817 yr when i do a HU install i run a wire from the kick panel up to the ground wire from the HU.and the stock 12v wires from the harness should be good.
December 25, 200817 yr Author one is memory back up lead and the other is bus power lead... ill use the harness and run my own ground to the kick as suggested. thanks for the input.
December 25, 200817 yr i think all clarions have the 2 constants and 1 switchable. and of course the one ground.
