Posted December 25, 200817 yr In order to get a 1 ohm load out of the 2OHM DVC,I wire the two negative terminals together with speaker wire coming out of one of them,and both the positive terminals with speaker wire coming out of the same set that the negative came out of right?
December 25, 200817 yr http://www.the12volt.com/caraudio/woofer_c...sp?Q=1&I=22+ to + and then out of the box to the + on the amp.- to - and then out of the box to the - on the amp. Edited December 25, 200817 yr by KHARPS
December 30, 200817 yr If i have 2 Fi 15" Q's at 1 ohm each, how do i wire them to create a 1 ohm load. Thanks
