December 31, 200816 yr Author It was off. I think there is something wrong with the amp i received.I tried hooking another amp to my sub and it worked and i tried hooked different subs up to the 1000D and it still didn't work so im sending it back to jacob.
December 31, 200816 yr that sucks man was the box fudged up when you got it could have been droped or something
January 1, 200916 yr Author Nah, the box wasn't messed up. A wire could have been knocked loose though inside or something. Edited January 1, 200916 yr by juslivin
January 1, 200916 yr I'd be hesitant to send the amp back when you still have not pin pointed the problem. The may not be outputting anything because there may be nothing inputting. If you LOC is bad, then your amp won't have any input. Check the outputs on the LOC and see if they are outputting anything.I saw once come into the store this past week. The kid fried the fudge out of it. Send the amp back if or when you are sure it is the amp.
January 1, 200916 yr Author I'd be hesitant to send the amp back when you still have not pin pointed the problem. The may not be outputting anything because there may be nothing inputting. If you LOC is bad, then your amp won't have any input. Check the outputs on the LOC and see if they are outputting anything.I saw once come into the store this past week. The kid fried the fudge out of it. Send the amp back if or when you are sure it is the amp.I checked the amp with a multimeter today and there is power going into the amp but no power coming out.Why would this be?I hooked different subs up to the amp and they didnt work and then i hooked a different amp up to the sub and it worked..... Edited January 1, 200916 yr by juslivin
January 1, 200916 yr You swapped amps then?I was thinking you tried your sub in a completely different car. Doh
January 1, 200916 yr I checked the amp with a multimeter today and there is power going into the amp but no power coming out.Why would this be?When you say there is power going into the amp are you talking about the positive and negative terminals or the rcas?
January 1, 200916 yr I checked the amp with a multimeter today and there is power going into the amp but no power coming out.Why would this be?When you say there is power going into the amp are you talking about the positive and negative terminals or the rcas?I'm 99% sure it was 12V he checked. Not RCA's.
January 1, 200916 yr Author I checked both.I don't see why one amp would work with the same rcas and LOC and then the sundown not work though.I also looked inside of the amp and everything seemed ok.
January 1, 200916 yr If you swapped amps and everything worked, then it has to be the amp. Like I said i was under the impression that you put your sub in a different vehicle to see if the sub was bad.
January 2, 200916 yr Try swapping RCA's. Sundowns are notoriously picky on what RCA's are being used.
January 2, 200916 yr UH OH! Please tell me Sundown amps are ok with memphis rca's.. that would suck!! Sorry to O.P. for the slight thread jacking.
January 3, 200916 yr Author I tried my new knukonceptz rca and also my scosche rcas which are very similar to what jacob said he uses, (which are also scosche).
January 3, 200916 yr I tried my new knukonceptz rca and also my scosche rcas which are very similar to what jacob said he uses, (which are also scosche).Double check your ground, my 100.4 was picky about its ground.
January 3, 200916 yr Author Already dropped it off at the UPS store on wedesday, still only says billing info shipped. I wonder why.
January 6, 200916 yr Already dropped it off at the UPS store on wedesday, still only says billing info shipped. I wonder why.It will say billing info until it scanned in @ the first terminal location and sorted for the first time. After that will be able to track it
January 6, 200916 yr I hate to hear that you got a DOA amp, hopefully will get it all fixed and pounding before to long
