Posted January 9, 200916 yr looking for a few different options to power a 10" DCON. Right now i have a Kenwood 9104D running at 12.2 volts putting out 402watts RMS at 4 Ohms. Should i stick with this or go another direction?
January 9, 200916 yr before you consider upgrading amps i'd consider trying to get the voltage up because you will just start killing other amps.
January 9, 200916 yr Nothing wrong with 12.2v... possibly all his car outputs.That amp will be perfect for a single DCON
January 13, 200916 yr Admin If you decide to get a different amp to match the 2 ohm mono load, the PG RSD300.1 and Kicker ZX300.1 are both great choices.
