Posted January 10, 200917 yr I was wanting to know some information on warranties, today i was listening to my 15 and in made a horrible sound and I shut it off instantly and I took it out of the box to look at it because I tried to push on the sub a little bit to see if there was any movement and there wasnt but I can push it from the back and it moved up, but the i noticed the magnet has cracked twice around the magnet and in between the two cracks had shifted to one side sticking out further than the rest of the magnet.any advice would be appreciated.
January 10, 200917 yr get a new mag replacementHe needs a new motor.And the only way that should have cracked like you describe is if you dropped it.
January 10, 200917 yr Author get a new mag replacementHe needs a new motor.And the only way that should have cracked like you describe is if you dropped it.I didn't drop it thoughhow much would a magnet and a recone cost?
January 10, 200917 yr They dont crack by themselves.Anything you can think of that might have caused it?
January 10, 200917 yr Author They dont crack by themselves.Anything you can think of that might have caused it?the box jumping a little? or the were two screws loose.so the warranty most likely wouldn't cover it?
January 10, 200917 yr They dont crack by themselves.Anything you can think of that might have caused it?the box jumping a little? or the were two screws loose.so the warranty most likely wouldn't cover it?And what made the box jump "a little"?
January 10, 200917 yr Author They dont crack by themselves.Anything you can think of that might have caused it?the box jumping a little? or the were two screws loose.so the warranty most likely wouldn't cover it?And what made the box jump "a little"?Im not sure. It wasn't screwed into the truck or anything.
January 11, 200917 yr They dont crack by themselves.Anything you can think of that might have caused it?the box jumping a little? or the were two screws loose.so the warranty most likely wouldn't cover it?And what made the box jump "a little"?Im not sure. It wasn't screwed into the truck or anything.So how exactly were you driving when you cracked the motor? Was the box shifting and sliding all over the place?Sounds like it was your bad though the way we're having to pull information out of you.
January 11, 200917 yr Author They dont crack by themselves.Anything you can think of that might have caused it?the box jumping a little? or the were two screws loose.so the warranty most likely wouldn't cover it?And what made the box jump "a little"?Im not sure. It wasn't screwed into the truck or anything.So how exactly were you driving when you cracked the motor? Was the box shifting and sliding all over the place?Sounds like it was your bad though the way we're having to pull information out of you.It might have been my fault but I wasn't driving I was just sitting in my drive way with the trunk open showing it off to a friend.
January 11, 200917 yr You'll have to send it in regardless.I'll get you an RMA number tomorrow night if not then Tuesday. I will not be back until very late Monday night.Thanks,Nick
January 11, 200917 yr Author You'll have to send it in regardless.I'll get you an RMA number tomorrow night if not then Tuesday. I will not be back until very late Monday night.Thanks,Nickalright.thanks.
January 12, 200917 yr The box could jump around all it wants, but as long as the sub was screwed into the baffle the motor should not have undergone any stress... Maybe it got dropped in the mail when it was shipped to you and the crack just took time to manifest itself.
January 12, 200917 yr Author The box could jump around all it wants, but as long as the sub was screwed into the baffle the motor should not have undergone any stress... Maybe it got dropped in the mail when it was shipped to you and the crack just took time to manifest itself.If it had gotten dropped how could the magnet just crack like that one day?
January 12, 200917 yr The box could jump around all it wants, but as long as the sub was screwed into the baffle the motor should not have undergone any stress... Maybe it got dropped in the mail when it was shipped to you and the crack just took time to manifest itself.I live 2 doors down from him and i was there it really just stopped workin. I thought he melted it. But i wasnt sure, it was bumpin about how it usually does then, it started getting crazy excursion. and just stopped working. Then we took it out of the box and saw the the magnet was cracked 2 times all the way aroun like you saw in the pics. Personally i dont know how it happened, but i can assure you that it really wasn't dropped. I'm not saying the its Fi's fault, and maybe nicks right it might have been dropped in shipping and we never noticed it, but hes had it for close to a year now and wouldn't have cracked before or maybe since we live in Indiana and it just got cold that may have caused it to. A sudden change in temperature????
January 21, 200917 yr Author You'll have to send it in regardless.I'll get you an RMA number tomorrow night if not then Tuesday. I will not be back until very late Monday night.Thanks,NickHey, I was wanting to know if you have gotten that number.
