I have decided to go with 2 FI Q-12 what advice would you give for the amp around $500
I had thoughts of a ZRS-8000D or a GP3000D-pro and ideals, Thanks
anything that would give your subs at least 1000rms, i would recommend a Incriminator Audio 20.1, but you said $500, which is way less. you can do (2) nine.1's strapped, those amps are 1200 @ 1 ohm @ 12v, so pretty underrated. if you go with the crunch, i'd invest in the bp option so they can handle all that power. just a fyi
  • Admin
What are your goals from this install?
I decided to go with the GP3000D-pro I figured with 2 FI Q12 I could beat the hell out of them in a sealed 1 cuft box with out working the amp to death :unsure:
  • Admin
He means options that are available.
