Posted December 17, 200322 yr Is the tsunami DB440 amp any good? What other amps would be comparable?
December 17, 200322 yr Admin it is a decent 4 channel, and great for the money, speaking of money how much are you willing to spend?
December 19, 200322 yr Admin keep in mind thats a very tight budget but here are a few solid ones to start with:http://www.purecaraudio.com/index.asp?Page...ROD&ProdID=1824http://www.purecaraudio.com/index.asp?Page...PROD&ProdID=622http://www.purecaraudio.com/index.asp?Page...ROD&ProdID=1867you can probably get this RF amp cheaper from Casey at www.kickinaudio.comhttp://www.infinitecaraudio.com/cgi-bin/ic...logno=OctaneR54but if you can spend a few extra dollars this amp is worth it for the price IMOhttp://www.cbrstereo.com/Merchant2/merchan...y_Code=SPECIALSgood luck
December 19, 200322 yr Author keep in mind thats a very tight budget but here are a few solid ones to start with:http://www.purecaraudio.com/index.asp?Page...ROD&ProdID=1824http://www.purecaraudio.com/index.asp?Page...PROD&ProdID=622http://www.purecaraudio.com/index.asp?Page...ROD&ProdID=1867you can probably get this RF amp cheaper from Casey at www.kickinaudio.comhttp://www.infinitecaraudio.com/cgi-bin/ic...logno=OctaneR54but if you can spend a few extra dollars this amp is worth it for the price IMOhttp://www.cbrstereo.com/Merchant2/merchan...y_Code=SPECIALSgood luck I wont touch rockford personaly i think its garbage. Pheonix i dont like octane i think im gonna go for the tsunami tho the orion is probably good i found out its only 50watts x 4 rms as opposed to the tsunamis 75 x4
December 19, 200322 yr Admin the RF is a great little amp for the money, and the PG Octanes have been getting great reviews for entry level line amps
