Posted January 19, 200917 yr Since I have a son my girl wants a car seat in both cars I have to take the 15s out the back seat and I won't be able to do my dp21I'm thinking about 3 10s facing into the car and porting the back deck. I'm about to pick up a crunch 3000d and its going into a 02 Pontiac sunfire. The set up is going to be used more for everyday use tuned in the low 30s. the trunk is and will be sealed off from the trunk and the subs behind the back seat with about 5in of spaceRight now I'm thinking of fi Qs, ssd, aq2.5s or dc lv4 can u think of anything better?I'm going to use 2 6in Euro ports on the back deck where the 6x9s used to go. Do you think it will sound good or should I use 2 10s with a flared slot port facing into the car?
January 19, 200917 yr My buddy did 3 1508's in his fusion, and they sounded pretty good. He had the port firing out the back deck, he made a custom back piece though.
January 19, 200917 yr This is how it was before he ripped it all out.http://www.caraudio.com/forum/showthread.php?t=352513
January 20, 200917 yr Author the trunk is and will be sealed off from the trunk and the subs behindhuh?i ment the trunk is sealed off from the frount of the car, i typed that with my phone at work.also its going to be used for everyday use so the goal is to have a loud system that can go low. if anything i might do bassrace 139 but thats about it
January 20, 200917 yr ...Three SSD Tens Or Like....6 Sundown e8's. Maybe Even 2 12" Incriminator Audio Flatlynes.
