Posted January 24, 200916 yr getting ready to place an order for my Fi Q series 15's but not sure what amp to use. I havw a Jl1000/1 i'm useing currantley. I know that this this is not going to be enough to power the two subs,but will a fosgate t-2000 be enough or should i look for something bigger?Need to figure out what amp to go with befor i can order my speakers.
January 24, 200916 yr I have the T2000's for my BTL's and they are straight amps..I havent hooked them up yet, But they are straight..I seen how the T1000 puts out power to my buddies woofers..So the T2000 is straight..
January 24, 200916 yr Author o.k. so if i go with a t-2000 I need to order the d-1's if running two correct?
January 24, 200916 yr Yeah if your running both subs on one amp at a 1 ohm load then yes go with dual 2 ohms..
January 24, 200916 yr Yeah if your running both subs on one amp at a 1 ohm load then yes go with dual 2 ohms..Ummm no. He needs to order D1 ohm.
January 24, 200916 yr Wait wtf am I talking about..Wont running two 2 ohm subwoofers end up at .5 ohms?
January 24, 200916 yr Author thats what i thought if i get two d-2's that would put me at 0.5, so i need d-1's to get 1.0 ohm.
January 24, 200916 yr My bad..I keep thinking your gonan run one amp per sub like me..Yeah get dual one ohm coils then..
January 24, 200916 yr thank's for all the help guy's.No problem. Good job double checking with us on your part.
January 24, 200916 yr Yeah Idk where that one came from..The chit im smoking these days heh Lol!Yeah that amp should be great. My T10001bd does everything I want it to.
January 24, 200916 yr I have the T2000's for my BTL's and they are straight amps..I havent hooked them up yet, But they are straight..I seen how the T1000 puts out power to my buddies woofers..So the T2000 is straight..As opposed to......unstraight amps? Homosexual amps? crooked amps?
January 24, 200916 yr Lmfao!My bad again!Nah In my eyes they look to be alright amps..Well built and put out power..Unstraight? Lmfao!
January 24, 200916 yr I have the T2000's for my BTL's and they are straight amps..I havent hooked them up yet, But they are straight..I seen how the T1000 puts out power to my buddies woofers..So the T2000 is straight..As opposed to......unstraight amps? Homosexual amps? crooked amps?watch out for crooked amps, they may steal your batteries' power when you are not looking.
January 25, 200916 yr getting ready to place an order for my Fi Q series 15's but not sure what amp to use. I havw a Jl1000/1 i'm useing currantley. I know that this this is not going to be enough to power the two subs,but will a fosgate t-2000 be enough or should i look for something bigger?Need to figure out what amp to go with befor i can order my speakers.i have the same amp (JL 1000/1) powering 2 15 w3's but am about to buy 2 15 Q's also. if you use the jl amp before you get the fosgate amp let me know what they sound like since i'll be using the 1000/1 to power them for a while.
January 25, 200916 yr Author change of plans was looking around and found another Jl1000/1 . Got a deal so i'm going to run one sub on each, i wanted to get a t-2 but a little out of my budget now .I still plan on getting a t-2 or perhaps a t-4 but for now will work with this.trying to decide wether or not to leave my box as one chamber or two separate, i know it's better to divide the box but the room i have is tight now . If I slit the box not sure if i will have enough air space.
January 25, 200916 yr change of plans was looking around and found another Jl1000/1 . Got a deal so i'm going to run one sub on each, i wanted to get a t-2 but a little out of my budget now .I still plan on getting a t-2 or perhaps a t-4 but for now will work with this.trying to decide wether or not to leave my box as one chamber or two separate, i know it's better to divide the box but the room i have is tight now . If I slit the box not sure if i will have enough air space. It doesn't matter if they are divided or not.
