January 25, 200916 yr the build im working on im doing both. i have a passive setup for the comps but between the comps and midbass its active. using a 4ch ch1&2 for the comps and ch3&4 for the midbass. Edited January 25, 200916 yr by dbjunior
January 25, 200916 yr Author the build im working on im doing both. i have a passive setup for the comps but between the comps and midbass its active. using a 4ch ch1&2 for the comps and ch3&4 for the midbass.i never thought about doing that.. what comps and midbass are you using?
January 25, 200916 yr cadence cvl-5k they sound great and get loud. the midbass is tangband w8-740p im gonna change them to most likely dayton Qt-210-4 8's the w8-740p is a better sub than midbass, the freq fade after 100hz so i need something capable of a higher range.
January 25, 200916 yr Author sounds like a cool set up.. what kink of power are u sending them? also what sub do u have?
January 25, 200916 yr the amp is 150x4 i have a q18 but will be using a pair of dc lvl4xl10's tuned to 32hz for daily. i havent gotten much done lately with a foot of snow on the ground and no garage.
January 25, 200916 yr Author awesome.. yeah this cold weather sucks.. ive got two rolls off raamat for my blazer but its too cold to put it in.. think im gunna get the stereo for my tahoe first then the blazer.. got an old set of boston acoustic comps for the tahoe, just need a cd player and amp now.. its gunna be my winter vehicle so i shouldnt need anything more than a set of comps in it..
January 26, 200916 yr I voted for active, but I haven't built yet. I need to wait for the snow to melt....I believe I'll be running MLI6.5's and seas neo tweeters though.
January 26, 200916 yr I voted active since that is what the future plan is. Currently I am running Passive to my components and active on my mid-bass.
January 26, 200916 yr Author if i wanted to have a 6.5" dedicated midbass in the stock door location could i also put the midrange speaker in the door? or would having them both in sealed door mess up the sound
January 26, 200916 yr I'm also running passive to my comps and active to my midbass. Actually have them ban passed from 500hz down to 80hz. What crossovers do you guys recommend for doing 3 way active?
January 26, 200916 yr Active all around. At first I was running passive, then I ran new speaker wire and got the 9887 and it made such a difference in SQ and how loud they could get without distortion. Also makes it easier to blend the sub with your fronts.
January 26, 200916 yr I have run full active in the past.....the passive X-overs that came with my 660gti components areun real..the fully active system had nothing over them.....but they are the size of most amplifiers
January 27, 200916 yr The build I'm working on will be active all around. I'm using the crossovers on my SAX-100.4s.
January 27, 200916 yr I have run full active in the past.....the passive X-overs that came with my 660gti components areun real..the fully active system had nothing over them.....but they are the size of most amplifiersI will agree with you that high end crossovers sound better than anything, but there expensive to buy\build! Edited January 27, 200916 yr by sick6ness
