Posted January 26, 200917 yr my friend wants me to build him a box for 2 12" rf p1's. right now hes using a pre fab box that is complete garbage. its for his dodge daytona, which is a hatchback, any tips on what size sounds good, or what airspace sounds good for a ported box, or if sealed sounds better with those, because i have no idea. thank you very much
January 26, 200917 yr From the Rockford Fosgate website...Description Size 12" Impedance 4-Ohm Power Handling 150 Watts RMS 300 Watts Max Voice Coil Diameter 1.5" 6-Layer (3.81 cm) Motor Size 40 oz. Speaker Connector Dual 10 AWG compression SPL (1w/1m) 86 dB Mounting Depth 5.875 in. (14.92 cm) Shipping Weight 12.50 Lbs. (5.67 Kg.) Rec. Sealed Enclosure 1.02 cu. ft. (28.88 liters) Range: 0.70 cu. ft. - 1.80 cu. ft. Range: (19.82 liters - 50.97 liters) Rec. Vented Enclosure 1.79 cu. ft. (50.69 liters) Vented Tuning Frequency 36 Hz Port: (1) 3" diam. x 6" long Port: (1) 7.62 cm x 15.24 cm I would use the ported specs. Good luck!
