Posted February 2, 200916 yr Audioque HDC315 vs RD Alpha v2 15" D2Which does they beat harder?just curious.. my amp is Hifonics Brutus BXi2008D Class D AMPLIFIER 2000 RMS!1ohm 2,0002ohm 1,300 can gain amp to 1500 on gain so curious about it.. Edited February 2, 200916 yr by DEVO1
February 2, 200916 yr I don;t know about the RD Alpha sub but I just got some of the Audioque subs for a demo vehicle build and it those things slam. I am running a audioque 3500 per sub at about half gain.
February 2, 200916 yr Author I don;t know about the RD Alpha sub but I just got some of the Audioque subs for a demo vehicle build and it those things slam. I am running a audioque 3500 per sub at about half gain.thanks for feedback.
February 2, 200916 yr Audioque HDC315 vs RD Alpha v2 15" D2Which does they beat harder?just curious.. my amp is Hifonics Brutus BXi2008D Class D AMPLIFIER 2000 RMS!1ohm 2,0002ohm 1,300 can gain amp to 1500 on gain so curious about it..These are not the right questions to ask. It's ALL ABOUT INSTALLATION.Plus, I hate to break it to you or make your equipment sound bad, but that Hifonics does not put out rated power.Personally, I think I'd take a DC LV4XL over either.
February 2, 200916 yr Author llooks like dc lv4vl is smiliar with audioque.. but audioque got more db..
February 2, 200916 yr llooks like dc lv4vl is smiliar with audioque.. but audioque got more db..That doesn't mean too much lol. That's at rated wattage for one thing. When both the AQ & the DC can take twice their rated wattage. Plus, I'll state it once more, it's just about all in the install.
February 2, 200916 yr Author i dont know what i can comment now cause alot people mention audioque will be fine with my amp...
February 2, 200916 yr i dont know what i can comment now cause alot people mention audioque will be fine with my amp...yes it would. But I have read where people used an AQ1200d amp & then swapped to a AQ2200d amp & got a 3db increase. I don't know for sure whether or not this is true. So I'd say use your amp for now, then upgrade if you're not satisfied.
February 2, 200916 yr i couldnt figure out how much dcLV4XL cost its odd..Email or PM rusty for info. He's quick w/ replies. I don't think your supposed to give out the prices so I can't tell you. But, I will say this, it is pretty close to the cost of an AQ HDC3 aluminum coil.
February 2, 200916 yr also, just in case you haven't seen iamamp3pimp's set up here: That's about 4000wRMS to each. Unless he has them wired at .5Ω. If so, then he has more going to them than that.Those are the LV5s. Edited February 2, 200916 yr by kram3r
