:Doh: which of the old 3 slug options were cosidered basically universal, D1 or D2.
i bought my btl from teampsi on ca.com, on his ad he said its a D1 so its basically universal. i have read else where that the D2 were the ones considered universal.
can anyone clear this up? im about to order a recone, and i want D2's but i want to make sure it will fit!
thanks fellas
Universal: This option gives you the choice to later chance the impedence of your voice coils. You can change from dual 2
is there a way to identify a D2 from a D1, other than measurements? which i can check:)
Do you have a pair of calipers? You could measure the gap and then Fi can tell you what they can do for you. . .
bassahaulic it was a D1 before i took the cone off, and i will be measuring the gap at work today with a faro arm (3D mapping and precision measuring instrument)
its damned hard to measure a magnetic gap with metal calipers:D
Edited by lincolntc
gap measures .225 +/- .005
is that a tight enough spec.??
can i get a D2, ND??
Edited by lincolntc
wow you dont mess around
