Posted February 9, 200917 yr Is 1800 watts rms too much for a BL daily in 2.25 cubes at 32 hz? also how loud are these subs? this will be in a regular cab silverado.
February 9, 200917 yr its a little too much for the 1000 watt rms sub....they can take 1000~1500 clean power... i can only imagen you have a 1800 watt hifonics amp and your asking if that amp is too big for the sub?
February 9, 200917 yr thats enough amp for 2 BL 12's IMO, and if you wanna run 1 bl off that amp watch your settings.... and you will have a great match.. it will be a breeze for that amp.
February 9, 200917 yr If you get silly with the knobs then no it won't take it.If your conservative, it'l be fine.
