What do u guys thinks about Us Amps XT-4000d? Im thinking about buying it to power my Fi BTL 12". Good or bad choice?
It is an ok amp. BTL can handle more power, but if you are on a budget, it will work.
What is your budget? We may be able to offer advice one what other options are available.
around 200 to 300 dollars.
Are we to assume your BTL is a dual 2 ohm sub? I went through our distributor inventory, and it is going to be a very limited selection of high quality amplifiers that do over 1500 watts for less then $300.
yea its the 2ohm sub. wut are some of my options?
buy a saz1500d and add a second with batteries and alternator when you have the money, that way you don't have to dump tons of money into batteries and a charging system at the same time you hook your amp up.
ive heard about saz1500d never used it though, about how much is it
Very capable amplifier, but a bit out of the budget for this install. Maybe consider the Cadence iA7.
I have a Us amps amp and it is supposedly no matter what puts out its rated rms.
Edited by ADK
