Wondering if these specs on this sub is available. its a dual 1.1
Electrical Q Value -Qes: ??
Mechanical Q Value -Qms: ??
Total Speaker Q Value -Qts: ??
Free Air Resonance -Fs: ?? Hz
Equivalent Compliance -Vas: ?? liters
One-Way, Linear Excursion -Xmax: ?? mm
Efficiency -SPL 1W/1m: ?? dB SPL
Effective Piston Area -Sd: ?? cm^2
DC Resistance -Re: ?? ohm
Nominal Impedance -Znom: ?? ohm
Thermal Power Handling -Pe: ?? W
Force Factor -Bl: ??
Even if you had the specs, you more than likely would not like how they model up.
Run them in 6.5-7.5 ft^3 tuned to 35 hz for daily. Each one on a 40.1 will be awesome.
actually..... all on 16v too ;)
this is not going to be a daily
If not daily, who needs t/s parameters?? Test and tune is the only way to get max SPL. . .
oh thats cause only 3 are going in an spl vehicle. sorry for the confusion
  • 3 weeks later...
