Posted February 24, 200916 yr well my friend bought subs, an amp, and a box from bestbuy. so i told him to let me install it but he said his neighboor has alot of experience (which wasnt true). so any way the guy hooked it all up. he did a nice job on the electrical wiring but when wiring subs to the amp he ran the wires in series which presented an 8ohm load and the amp isnt made for 8 ohms. he was supposed to run them in parallel. im not sure y it worked but it did. then my friend said the amp kept shutin off after a few minutes of play, but then would turn back on in about 7 seconds. but my friend kept on bumpin for like an hour. then i went over there today and rewired the subs in parellel and we bumped it for a lil and he said it must be fixed cuz it usally turns off by now. but then it turned off. and then back on again. so my question is do u think my friends amp is done for good or is something else the problem?the subs are 2 12" kenwoods single 4ohm voice coils, the amp is a monoD kenwoodsub model=KFC-W3011amp model= KAC-8104Do ya it doesnt seem like a voltage problem either.
February 24, 200916 yr well my friend bought subs, an amp, and a box from bestbuy.Theres your problem
February 24, 200916 yr by the way i may be wrong but i dont think u can ruin an amp by running it at a higher ohm load. now a lower ohm load is a different story
February 24, 200916 yr check the whole wiring might have a loose cable somewhere or something is hitting your power wire like a nail and is causing to protect it self
February 24, 200916 yr Author to juslivin: haha ya i no best buy wasnt a good idea.well the amp isnt actually going into protection mode it just completely shuts off.it is grounded to the the hinge of the trunk and the paint is sanded.and i do not think the power wire is touching anything.
February 24, 200916 yr Needs to be grounded to chassis (Frame) of car not the sheetmetal body!The sheetmetal doesn't carry the same resistance as the chassis.I bet 99% that's the problem.
February 24, 200916 yr hinge of trunk=ground=problem.... bad idea from the get go...sounds like a loose connection somewhere though.. has to be loose power, ground, or remote line for the amp to just shut off with no lights
February 24, 200916 yr The frame is the best... but even just the trunk floor is 20 times better than where it's grounded now..
February 24, 200916 yr Cheap way... Wrap it around a mounting bolt on a seat..(shine it all up first) At least the bolt is threaded into the frame.Correct way... drill a hole, add a grommet through the wall or floor then find a good spot, easy to get to, drill a hole either through or thread (tap) into the frame, clean it up till it shines, slap a ring terminal on the end of the wire, use a stainless bolt with washer. Sheetmetal grounds are good for things like lights and acc.that's about it.
February 24, 200916 yr Author should i just screw it into the floor with regular screws or do i need to do something different? sorry for all the questions, i just dont have alot of experience yet.
February 24, 200916 yr I've seen the problem happen at least a couple dozen times...It's a very common mistake. (One of the most common)A lot of people just don't know,I didn't at first either.Since i've done it the righ way for years now,I've never had a problemand it fixes this issue every time.
February 24, 200916 yr Or atleast it's a start in the right direction.It the amp getting hot in any way?
February 24, 200916 yr Making the amp see a higher impedance is not going to be a problem, check the wiring and make sure you have a good ground.
February 24, 200916 yr Author ok i will go to his house tommarro and c what i can do with the ground and hopefully it works.and thanks to all u guys that helped me. thanks for all the fast replies.wow u guys r repling so fast i cant keep up.the amp is not getting hot. Edited February 24, 200916 yr by burbank bass crew
February 24, 200916 yr I like trying to help!Plus it's a learning experience to read about other's problems.Them Gremlins are everywhere just waiting to booger up an install!It's half the fun tweeking out the bugs!
February 24, 200916 yr the amp is not getting hot.I'd say it's the ground location then.Like I said, I'm 99% positive on this one.Gotta leave 1% for error! LOL
February 24, 200916 yr Author ok i will difinetly give it a try and hopefully make my friend happy.but i have homework to do so i think im getting off. peace everybody.
