Posted February 27, 200917 yr im thinkin about getttin 2 kinetik hc2000 and a high output alternator for 2 12 btl's...anyone got any comments...jw if thats over kill or do i need more.
February 27, 200917 yr Make sure to do the big 3 when you put the new alt in, otherwise youll be wasting your money.
February 27, 200917 yr Your electrical isn't dependent on what subs you're using....What amp are you running?
February 28, 200917 yr sounds like you are doing everything you should be to run that amp properly. I'm sure you are, but make sure to read up through the sundown forums on that amplifier, sundown amps are great, but to make sure you get everything out of it and to be sure it is installed 100% properly I would say learn everything about it that you can.
February 28, 200917 yr Where would i find a forum for it at??scroll down on main forum page...lolIt hasn't been released yet (mid May is the ETA I believe.)Get in touch with "sundownz". He should be able to help you out the most.
February 28, 200917 yr yeh sundown audio is also on the SSA forums just go to manufacturer forums and go to sundown audio. Sundownz is Jacob Fuller, the owner of sundown audio, obviously a good resource. Jacob knows his stuff and is great to work with.
February 28, 200917 yr Author no new to this whole forum..lol ive been in audio for bout a year or two...nothin really serious though...anyone got an idea on what size alternator to run wit that amp??
