Posted March 9, 200917 yr Hello all,looking for some guidance .. I am considering purchasing 2 FiQ 10's and using a AQ 1200 D to power them.. I am unsure on the options. i am assuming dual 2 ??? I drive an Xterra so i am considering building a box that would fit behind the rear seats following the slanted contour (thin on top to larger on the bottom) with the amps attached to the back of the box... I figure 2 10's because it would look better than 1 but not sure if i need 2.. Any opinions, thoughts, box ideas would be more than welcome.. Definitly looking for SQ and not SPL. dave
March 9, 200917 yr There is no point of getting two tens with a 1200 rms amp. thats enough power for one if you want two you would have to get the aq2200
March 9, 200917 yr There is no point of getting two tens with a 1200 rms amp. thats enough power for one if you want two you would have to get the aq2200Not true. You don't need to power the Q to it's thermal limit for it to sound good. 600w/sub will be more than enough.You'll want the DVC 1 ohm subs though..
March 9, 200917 yr Author Is worth moving into the 2200D for the extra 120 bucks? And the general census would be go for the 2 10's? ..
