i was wondering how muc amplifierpower i would need and whatkind of amp to get?
Something that will to 1,500-1,600 watts RMS at 2 ohms. Kicker 1500.1 would, or a Sundown SAZ-3000D.
what would the amplifier of choice be at dual 1 instead
same type of sub
Well with TWO dual 1's the amp I would recommend is the Sundown SAZ-1500D
so the sundown 1500 would handle both subs witno problem all the way to max peak power
Just wondering, do you know what watts RMS is?
so would that amp onlyhave enough power tohandle those two subs?
or would it hve extra power?
The SAZ-1500D puts out about 1,700 watts RMS at 1 ohm. You would run both.
im kina new to this if u canttell
how can you tell much power the amp will have to have for the subs
2 D2's = final load of 2ohm (rare to find an amps max output @2ohm.
2 D1's = final load of 1ohm (1ohm stable amps are EVERYWHERE)
Edit: Is that you in your avatar? Looks like your chitting your pants.
Edited by SEC
