Posted March 22, 200917 yr after reading some post on setting up my active front stage id like to go back and do it with pink noise. anyone got a place i can get it from?
March 22, 200917 yr after reading some post on setting up my active front stage id like to go back and do it with pink noise. anyone got a place i can get it from?Here you go: http://www.realmofexcursion.com/downloads.htm Tones, sweeps, noise,... Its all there.You can also download and install Audacity and make your own, pretty easy to do.
March 22, 200917 yr Author thanks man, anyone know if i should use the mono or stereo version to set individual gains?
March 23, 200917 yr You should use a sine tone for setting gains. It is really hard to see distortion with pink noise on an oscope
March 23, 200917 yr Well, to set your gains, I would use single tones so you can see the sine waves on an o-scope to make sure it was not clipping (not a flat top). I would use the noise with an RTA to set the eq levels (not gains) to make sure you have a flat response, then adjust to your ear from there.Edit: M5, beat me to it hehehe Edited March 23, 200917 yr by bobonit
