Posted March 24, 200916 yr Hey guys i have these 2 fusion powerplant mono block d amps that are 2000 watts. i was wondering if these amps are good enough and will suply ample amount of power to 2 15" bl's fully loaded? here are the specs. thanks again for all the help! Product Specifications465 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N750 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N1150 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+NLinked Power Ratings @14.4VDC1000 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N1800 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+NMax Power Rating: 2000 WattsMax Current: 100AFull Rated Power Distortion (Max) 1kHz: 0.45%THD @ Rated Power 1kHz/100Hz: 0.3%Frequency Response Hz (-3dB): 10Hz - 250HzSignal to Noise: >90Variable Low Pass Filter: 12 dB/OctaveBass Boost @ 45Hz: 12dBInput Sensitivity: 0.2 - 8VInput Impedance: 47KFuse Rating: 25A x 4
March 24, 200916 yr Author i was told that they do but am not sure i havent really herd of fusion amps before and cant find any reviews ave you delt with any or herd anything good about them?
