Posted March 29, 200916 yr Would a the US Amp MD 2D be enough for 2 10" SSDs with the copper coil? The does the amp really produce 1500 watts at 1 ohm? Or is it overrated?
March 29, 200916 yr If it puts out that many watts, it would be a good choice for a pair of SSD's. I'm not familiar with it though.
March 29, 200916 yr Author If it puts out that many watts, it would be a good choice for a pair of SSD's. I'm not familiar with it though.yeah well theres a US AMPS section on the SSA forums and i found it cheap... $269.95! When everywhere else has it for around $800
March 30, 200916 yr Author MD2D, not familiar with the site.I know so im going to get a better site to match the deal hopefully
March 30, 200916 yr MD2D, not familiar with the site.I know so im going to get a better site to match the deal hopefullyThey usually have to be an authorized dealer to do a price match.
March 30, 200916 yr Author MD2D, not familiar with the site.I know so im going to get a better site to match the deal hopefullyThey usually have to be an authorized dealer to do a price match.okay well i shot an email to this one good site (cant remember the name)... but if they have a reputable ebay account then i bet they are fine
March 30, 200916 yr Author so will the amp produce 1500 watts at 1 ohm? or do you think it is overrated?
March 31, 200916 yr Author Pretty sure the merlins do ratedGreat! But i read they do 1800 at 1 ohm... Do you believe it?
March 31, 200916 yr Pretty sure the merlins do ratedGreat! But i read they do 1800 at 1 ohm... Do you believe it?Could be true, whats the fuse rating on them?
March 31, 200916 yr Author Pretty sure the merlins do ratedGreat! But i read they do 1800 at 1 ohm... Do you believe it?Could be true, whats the fuse rating on them?40x3
March 31, 200916 yr 1500 Watts At 1 Ohm For $269 ?HmmmI Would Have To Say Its Overrated.Usually Amps That Put Out 1500 True Power Are Within A Price Range Of $300 - $ 500However I Could Be WrongWhat Is The Fuse Ratings On IT ?40X3....You Do 40 X 3 = 120.So That Gives You A Total Of 120 Amps.Times That By 12 Volts Which equals 1400I Dont Know What The Efficiency Rating Is On The Amp But The Amp Is A Bit Underrated.However Id Does Put Out 1400 Watts At 1 Ohm Which Is Close To What You Said.Do You Know The Efficiency % Of The Amp ?I Could Tell You The Exact Amount It Puts Out.Thanks
March 31, 200916 yr I looked At The Website And It Says The Efficiency Rating For 1 ohm Stable Is 77 %So 1440 X .77 = 1108 Watts RMSThats How Much The Amp Puts Out Safely At 1 Ohm StableHope This HelpedIf You Have Any More Questions Id Be Glad To Help. Edited March 31, 200916 yr by Kent
March 31, 200916 yr those EQUATIONS mean chit in real world ^^ read Edited March 31, 200916 yr by Tyan
March 31, 200916 yr hey Kent ! , can you tell me how much my amp puts out ,it is rated for 500W @ 2 OHM now it has 30 X 2 fuses so thats 60 X 12 volt = 720 but i dont know the Efficiency ??? it is Sony Xplod XM-1S Mono amp 290W @ 4ohm , 500W @ 2 ohm , 900W max i couldn't find the efficiency in the manual, can you help ?
March 31, 200916 yr 1500 Watts At 1 Ohm For $269 ?HmmmI Would Have To Say Its Overrated.Usually Amps That Put Out 1500 True Power Are Within A Price Range Of $300 - $ 500However I Could Be WrongWhat Is The Fuse Ratings On IT ?40X3....You Do 40 X 3 = 120.So That Gives You A Total Of 120 Amps.Times That By 12 Volts Which equals 1400I Dont Know What The Efficiency Rating Is On The Amp But The Amp Is A Bit Underrated.However Id Does Put Out 1400 Watts At 1 Ohm Which Is Close To What You Said.Do You Know The Efficiency % Of The Amp ?I Could Tell You The Exact Amount It Puts Out.ThanksI paid 240 shipped for a mtx ta81001 with three year warranty, bnib
