April 10, 200520 yr Oh yeah... I forgot. Which size of wire and fuse would you guys recommend? I plan on adding a small amp in the future to power some Alpine 6.5" Type X components but the total watts will be less than 2000. I still have an old Coustic amp that I may just use for the components if its good enough.. its a 600SE that requires 4 guage wire. Don't know too much about Coustic quality so I may sell it and get a Viper amp.Thanks, Plymouth Pryde<{POST_SNAPBACK}>1/0 gauge to the rear, distribute to 4 gauge for the amps.Fuse the 1/0 with a 300A fuse.
April 10, 200520 yr Admin ummm. i'm in southern illinois. i've got a few references on here if u want to check around.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee Wow I just saw that box you built in the Show Off section... I may go with you if your up to it lol. I'll let you know more when I plan to get it done... got a lil' while yet though.Thanks, Plymouth Prydeyou chose wisely my son haha anyway, kent has the skills for sure, I have seen more than enough of his work
