Posted April 15, 200917 yr right now i have 2 18" in a hatchback with subs up port back will i do better numbers with subs and port up and i have 100sqin of port will i bennifit going to 150sqin of port any help please
April 15, 200917 yr Yes you would benefit. It would raise efficiency. Although your Treo's could fail mechanically if you aren't careful with the volume knob.
April 15, 200917 yr you could try subs forward port up if there is room. you might also wanna try tuning a little higher for spl numbers.
April 19, 200917 yr Yes you would benefit. It would raise efficiency. Although your Treo's could fail mechanically if you aren't careful with the volume knob.so too much port area is harmful? never heard that.. im a noob so if u could please explain how?
