Posted April 27, 200917 yr Well im going to be purchasing a 12'' Fi BL im going ported tuned to about 32hz, So i want to feed it about 1000w due to my stock electrical.Dont care if its a 1Ohm amp or 2 Ohm because i havent ordered the sub yet..I figured id start with the amp so i have more options.Im really trying to stay under 300..250 if possibleHifonics?I was talking to a member here who had a 12 bl hooked up to a POWER ACOUSTIK BAMF-2000/1D, who loved it..So any help id appriciate it.
April 28, 200917 yr Author What about an Elemental Designs Nine.1? Edited April 28, 200917 yr by g2low
April 28, 200917 yr THE BEST AMP FOR THE MONEY RIGHT HERE. i mean it... take a look.http://www.db-r.com/sell/store2/index.php?...ath=65_67_69_81
April 28, 200917 yr THE BEST AMP FOR THE MONEY RIGHT HERE. i mean it... take a look.http://www.db-r.com/sell/store2/index.php?...ath=65_67_69_81That is a great deal on an amazing amp.
April 28, 200917 yr and you have a few options when going with an amp like this. you can get 1 D1 and run it 2 ohms, and get about 800 or so to it.. and that sub will be great.. and then that leaves you headroom if you wanne get a second D1 and then be at 1 ohm... for over 1500 for the pair.. again perfect. or get a 1 dual 2 and run a single sub at 1 ohm but watch your settings.
April 28, 200917 yr Or get the BL with a couple of the options and you could probably throw most of that amp on it
April 28, 200917 yr Or get the BL with a couple of the options and you could probably throw most of that amp on itSure he could...... if the amp was only 1500rms.....
