Posted May 6, 200917 yr running a single fi bl 15 on a saz-3000d at 2 ohms? would that be okay and not blow it the options i have on it is cooling,daily, universal d1 until i get my next fi bl its ported of course in a 4.5 cuft tuned to 30hz
May 6, 200917 yr because I have a 3kd and run it at 4until I upgrade to 2 subs Edited May 6, 200917 yr by blue fury
May 6, 200917 yr Author until i get my next fi blbasically i was wondering if it would do any harm to the subwoofer.im getting another fi bl 15 soon and wanted to run it 2x 1.5kw rms at 1 ohm and if it was okay for awhile to run a bl 15 at 2 ohms which it would be getting 1.6kw rms
May 6, 200917 yr you could run that amp at 1 ohm on a single 8... .... thats what the settings are for!!! dial it down.
May 6, 200917 yr Author you could run that amp at 1 ohm on a single 8... .... thats what the settings are for!!! dial it down.I was planning on buying a refurb one for like 500 bucks so i can pound the poop out of my car. would a 200 amp alt big 3 0gauge front to back and some XS powercells maybe one or two be sufficient to power this monster?
May 6, 200917 yr oh yes. just keep track of your amp hours... i think jacob ask that you have around 120 amp hours or so with of batteries. for a 1 ohm load.
May 6, 200917 yr i personaly i have 580 amp hours for my mine.. but i can so thinks some people can t:D
May 7, 200917 yr no not that kinda " what your gonna do with it"like if you already own subs that give you a 2 ohm load... then yes 2 1500's would be better.... or if you wanna show off multi amps sure.. i dont recall that 2 1500's give much more power then a single 3000's perhaps a few hundred watts more... not enough for the ear to see the diff.
