Posted May 16, 200916 yr thinking of either running 3 AQ SDC2.5 15's or 2 HDC3 15's...wondering what to tune them at. ive heard around 38-40 but that seems high. I had 2 BL 18's @ 33hz and liked the way that sounded so im thinking around 33-35 for the AQ's. Opinions por favor.....
May 16, 200916 yr You could get away with lowering the SDC but the HDC has too high of a resonant frequency for them super lows. When you tune 'em down that low that will get F'd up.
May 17, 200916 yr I built box for audioque hdc315 tuned to 40hz and it sounded perfect, and being tuned that high it still picked up the lows great. I also built one for 2 hdc312's in a blazer tuned to 38hz and it was same, very good
May 17, 200916 yr Straight from shizzzon and DJ and they should know Tune to 38 Hz for daily.......great all around40 Hz for a little louder, more SPL orientedTune to 35 if you want devastating lows and "ok" highs
May 17, 200916 yr I have two SDC2.5 12s if you want to trade They're pretty much the same as HDCs, just not as geared towards SPL
May 17, 200916 yr Keep the BL's as the downgrade is a silly idea.had to read that a couple of times to c what you were saying. commas are your friend
May 17, 200916 yr Keep the BL's as the downgrade is a silly idea.had to read that a couple of times to c what you were saying. commas are your friendPretty sure there is nothing wrong with that sentence.....except for the ' in BL'sGrammar>you And SDC<HDC....tis true
May 17, 200916 yr You made me re-read it about 4 times, but indeed the sentence is fine. The apostrophe is not supposed to be there indeed but BLs looks stupid but an error on my part.Moving that way is definitely a downgrade though.
