Posted May 23, 200917 yr Got a phoenix gold titanium 1000.2 and wondering what i should get a 15 bl daily driver @ 1 ohm or a 15 Q? itll be in a 93 civic in a 32 cu.
May 23, 200917 yr SQ or SPL?SQ-QSPL-Blwhat options are you wanting on each? Edited May 23, 200917 yr by watts09
May 23, 200917 yr Got a phoenix gold titanium 1000.2 and wondering what i should get a 15 bl daily driver @ 1 ohm or a 15 Q? itll be in a 93 civic in at 32 cu.Surely that doesn't mean 32cuft?
May 23, 200917 yr From what i know about that amp it is a 2 channel amp and 4ohms is what you going to get mono so you are going to need a dual 2 sub and series it up to 4 ohms but that amp is a strong old school amp and it would be more of a SQ amp so i would go with the Q
May 24, 200917 yr From what i know about that amp it is a 2 channel amp and 4ohms is what you going to get mono so you are going to need a dual 2 sub and series it up to 4 ohms but that amp is a strong old school amp and it would be more of a SQ amp so i would go with the QWhat determines if an amp is an 'ess que' amp or not... ? And what does is have to do with what woofer it will amplify ?
May 24, 200917 yr From what i know about that amp it is a 2 channel amp and 4ohms is what you going to get mono so you are going to need a dual 2 sub and series it up to 4 ohms but that amp is a strong old school amp and it would be more of a SQ amp so i would go with the QWhat determines if an amp is an 'ess que' amp or not... ? And what does is have to do with what woofer it will amplify ?that amp is a 2 channel class a/b amp they are mostly run on mids and tweets and when ran mono they tend to get hot but they have a lower THD than class D amps which are made to run subs and doing so they don't pick up those high frequencies like class a/b amps so they tend to run cooler because they play the lower frequencies only and don't have to play the while range all the time saving current to the lower tunes call for it that's why you see more people running class D amps for subs and with that mp 4ohmsis what it plays in mono if you go lower than the 4 ohms you cause that amp to overheat go into protect and most likely blow a good amp playing to low of ohms if you want to play under 4hms you should gt you a class D amp dual 2ohm subs can be series up to 4ohms and you will be safe
May 27, 200917 yr Author i figure i got that amp for free so i might as well put it to use, i really dont fell like dropping 4 hundred on a new amp.im kinda confused cause i was looking at those IA death penalty's and that dc sound lab level 3, but i really like that FI BL
May 27, 200917 yr Author basically i want my trunk to sound like it's ready to blow off, (no rattle already matted) i already got alpine type s comps all round and center channel for my mids and tweet, im just trying to figure what 15' sub i wanna get
May 27, 200917 yr just make sure you get a sub that is a 4 ohm load at the end like a d2 woofer to be series up to 4 ohms for a single woofer, if you are going to run 2 subs you can run 2 d1's or 2 d4'sa single 15 or 12 would be good but et the D2 series
May 27, 200917 yr basically i want my trunk to sound like it's ready to blow off, (no rattle already matted) i already got alpine type s comps all round and center channel for my mids and tweet, im just trying to figure what 15' sub i wanna get you want a BL. that amp will work fine on the dual 2ohm voice coil model.
May 27, 200917 yr basically i want my trunk to sound like it's ready to blow off, (no rattle already matted) i already got alpine type s comps all round and center channel for my mids and tweet, im just trying to figure what 15' sub i wanna get you want a BL. that amp will work fine on the dual 2ohm voice coil model.X2. Please do NOT get the Q
May 27, 200917 yr go with the bl but dont expect anything special with that amp. but u do have room to upgrade and thats always good
May 27, 200917 yr There is nothing wrong with that amp. I'd rather have it over some of the class D amps on the market.You may want to look into some FMODs to use as a subsonic as I believe that amp doesn't have one.
May 28, 200917 yr There is nothing wrong with that amp. I'd rather have it over some of the class D amps on the market.You may want to look into some FMODs to use as a subsonic as I believe that amp doesn't have one.i agree with bromo, that amp could pull more power than most stock japanese alternators will provide.
