Posted May 30, 200916 yr if i get a little mdf dust down by my coil etc, will it be fine and blow out eventually, or is it going to cause problems?
May 30, 200916 yr if i get a little mdf dust down by my coil etc, will it be fine and blow out eventually, or is it going to cause problems?I would try my hardest to get it out. You have any compressed air?
May 30, 200916 yr A damp rag works well. I know my subs came with a disclaimer for cleaning the box of saw dust.
June 1, 200916 yr someone on ca.com suggested something like a popsicle stick, with doublesided tape on it, basically anything you can slide down where the vc rests, and then blow it out while running the sticky stick around to pickup any things that flys around in there
