Posted June 2, 200916 yr Is there any advantage or disadvantage in going with the Bp version. Plus should I get the 2 ohm version? Right now Ive got 600w into 2 ohms.. The Pioneer Mono doesnt do 1 ohm... I will upgrade someday... And lastly with the SQ of this sub be much better than the Pioneer sub I have? Below are the specs and I know specs dont mean that much... Thanks for your responses in advance!!!MikePioneer TS-W1208D4Size 12"Woofer Cone Material Interlaced Basalt/Carbon Fiber Reinforced IMPP ConeWoofer Cone Design Cone Reinforcement ArcsSurround Wide Roll, Three-Layer Fiber Woven RadialVoice Coil 4-Layer, Long Voice CoilVoice Coil Wire CopperVoice Coil Bobbin Phenol Resin Coated Glass ClothDamper (Spider) Aramid FiberDamper Ring YesTop Plate StandardProjected Pole Yoke with Vented Pole Magnet Construction Double Mass High-Power (83oz)Basket Design Stamped Basket with Magnet CoverGasket ABSWire Terminals Integrated Single-Sided Silver Compression TerminalsSpecificationsWatts MAX. Music Power 1400 WattsWatts Nominal Power Handling 400 WattsFrequency Response 20 Hz to 180 HzSensitivity D2 (91dB) / D4 (92dB)Ohm Rating D2 (1 or 4 ohm) D4 (2 or 8 ohm)Recommended Enclosure 0.85 ~ 1.75 Cubic FeetDimensions 327 mm x 172 mmMounting Depth 153 mmAccessory Grill UD-G308
June 3, 200916 yr Advantage is extra cooling and mechanical durability. Disadvantage, slight loss in SQ vs standard sub.For those that need the extra power handling, the change in SQ in a ported application is really negligible. For SQ purists, standard version and power handling should be more than enough.If amp makes power into 2 Ohm mono... you would need a Dual 1 Ohm coil. Wired in series it will yield the proper single 2 Ohm load for the amp.Thanks,Scott
