Info:
2-10" Alpine Type-R's in a sealed enclosure made from 3/4" MDF
Volume:
.882 ft^3/sub
Inside dimensions:
10"x10"x15.25"/sub
Outside dimensions:
11"x11"x32"
Cut pieces:
2-32"x10" top & bottom
2-32"x11" front (subs will be mounted here) & back
3-10"x10" 2-sides and center divider
How does this look? I assumed that 3/4" MDF is like 3/4" plywood in that the actual thickness is 1/2", or am I wrong?
Thanks,
Ed
Actual thickness of 3/4" MDF is 3/4".
Have you included sub & center divider displacement?
Sub displacement was considered, .05 ft^3/sub. Should put me at .832 ft^3/sub which if I remember right is almost exact suggestion from Alpine for a sealed box. Center divider was factored into the length. Now I need to go back and figure everything in for the actual MDF thickness, inside dimensions will be the same, but outside will change. Glad I did figure a little small for the truck space it'll actually go into. Thanks ANeonRider, better to find out now rather than when I start building.
Ed
Also, MDF sheets are 1" larger for L and W.  So it'd be 49"x97"
yeah just big enough not to fit into the explorer to drive it home from home depot
:owned:
^^lmao...
man he dont drive a Neon, he drive an SRT-4 dawg
sweet car though...it would shure whip my trucks ass all over the pavement.
^^lmao...
it's still a neon, regardless of the turbo...:lol2:
now if it was a chevy colbalt ss...the supercharged version..then it wouldn't be quite so :greddy2: ..though the srt4 at least makes the neon a fast :greddy2::finger:
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
Yeah, tell that to the guy in the WRX I smoked from a dig. He lost to a Neon..Bwahahahahahahahahahah! :P
