I wanted to find out the best location for a line driver... (here by reffered to as LD)
by that I mean is there benifits of having the LD close to the HU unit?
or close to the amps?
for example in my truck amps sit in the rear
:huh:
beign a line driver, i wouldn't think it would matter where it's at..adn if anything, closer to the amp..i mean say it's a 16volt unit...regardless of what goes in (say 5 volts) it comes out 16 right??
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
well this would be for my truck, I have over 22' of RCA's to run, and I have always had my Overdrive up front, but there has been many pro spl installs where the overdrive or matrix is in the rear
as always, and no offense intended:
Install it upfront, get the amps setup and get a proper burp on the sensor.
Then, without changing any settings, rewire the LD at or nearto the amps, burp again. If there is a gain, keep it there.
Alot of questions on equipment theory come down to whatever is louder on the sensor / mic. As always, test & worship the TL's results. :D
What do you know? I was wondering where you've been. The JBL is supposed to arrive today. ;)
as usual, Nickypoo is right, I need to find some female to female RCA connectors and rewire it in the back
