Posted June 16, 200916 yr Need help with deciding on building enclosure for (2) 15" FI BTL. Going for ~36hzThis is the amount of room i would like to use:Width = 36" (Max width due to wheel.)Height = 24"Depth = 22"Would be sound better if the sub face up or sub face back. Also the same question apply to the port.All of this is going inside a SUV.What are your recommendation for the port?If the above measurement are small, please give me some recommendation. I would like to keep the box small but also sound good.
June 17, 200916 yr I liked sub and port rear in my SUV. Others will disagree. . .You have enough room.100-120 sqin of port area is enough. Example: 20" x 5" port x 19" long gives you 35 Hz tuning and 7.4 cuft net.
June 18, 200916 yr Author I liked sub and port rear in my SUV. Others will disagree. . .You have enough room.100-120 sqin of port area is enough. Example: 20" x 5" port x 19" long gives you 35 Hz tuning and 7.4 cuft net.If i was to change the height to 22 and the depth to 24? can i use the same port area..I was thinking of facing the sub up and the port to the back.
